13 years agohold slack violation
hi, i am using a clock period of 20ns(50Mhz) , in timing analysis constraints i set input delay max=10ns,min =5ns for input port, and set output delay max=5ns,min =2ns for output port. in ve...
13 years agoThere's not enough info in the screenshot. Run report_timing with -detail full_path, and add "-file ./TQ/TQ_failing_hold.txt". Then add the .txt file. (Analyzying the setup might be useful too.)
