hburd
4 years agoHLS compiler not generating IP components
I'm trying to build the example projects that come with the HLS compiler. When I build for the FPGA (e.g. running the makefile in the "counter" example), the compiler runs without indicating any erro...
BoonBengT_Altera
Moderator
4 years agoHi @hburd,
Thank you for posting in Intel community forum and hope all is well.
The steps that you have mentioned looks good, and usually the .ip files would be under the folder you have you ls on.
My guess would be there are some param on the compiled command that messed things up.
Perhaps can try the i++ compilation without the 'simulator' param or trying with the make command.
Hope that clarify.
Best Wishes
BB
