16 years agoHi ALL... I need help with the HDL code
Hi Im a beginner in HDL. I am given an SPI serial to parallel register and the inputs are clk, en and the serial data.. The register converts the serial data to parallel. The parallel data can be...
16 years agoHi,
ya that is the whole thing I have to do. So I splitted it up into two module. One with a faster clock and the other with SPI clock. what I actually want to know is HI, I have the following constraints. There is an enable. Whenever the enable goes low I have to take the incoming serial data at every posedge clk and I have to transfer the collected data as parallel out when the enable goes high. Now the serial data may be upto 75 bits. So I need to count the the number of clocks when enable is low and then transfer that many bits to out. My question is how should I do this transfer. I have declared a register Count. I increment this by 1 every clock cycle when En=0; But how to guide the transfer to output.??? I want to transfer the collected bits to output when enable becomes 1 using the register count. And it should be transferred to out only once when the enable goes from low to high. Please help me with this.... Thanks ak
