17 years ago
[HELP]question about loading different sof+elf files in remote upgrade
hello:
I've completed the things about loading application sof file in remote upgrade and that is successful.Now I want to load the sof+elf file.How could i do?Can i use the ide flash programmer to write sof+elf files to different address of epcs?And if i can't use the ide flash programmer,how could i write them to the epcs?The requirement of the form of the location of sof+elf files in epcs?
thanks
    Make sure your MSEL pins are set correctly. I remember this being a problem in the Stratix II.
    Jake
    Thank you Jake. They (MSEL) are set to 010 (AS 3.3V). What I find confusing is the ALTREMOTE_UPDATE document (Ch 3 - table 3-3) lists Remote Update params and available bits in each param, while the Cyclone III Device Handbook Vol 1 (Ch 9 - table 9-27) shows the Remote update status in one 32-bit register. And then there's the ug_remoteupdate PDF with more information. Following all the scattered documentation has made this more difficult.
    I do know the application configuration is loaded when the configuration is started and the bootstrap loads the factory NIOS II software. It is when the factory software runs that I want to check if it's in application mode and then in the NIOS II software load the EPCS data to RAM (upper) and copy this to lower RAM to run. I figured when I knew I could do this, then I'd move this logic to a custom boot copier.
    Thank you,
    Bill
    I am writting here because I am trying to find a way to program my .sof file and my .elf file on my EPCS but I do not know how to do this. I have tried with Flash Programmer but I have always the same error:
    Programmed 200KB +56KB in 4.6s (55.6KB/s)
    Did not attempt to verify device contents
    Leaving target processor paused
    I have also tried to program on my Flash but I do not know how to find the offset (in Flash Programmer) so everytime the Programmatin failed! Could someone help me please it is very very important!
    --- Quote Start ---
    --- Quote End ---
    This is not an error. This is exactly what you should see. With an EPCS device, the flash programmer programs the data but does not read it back for verification simply because it takes so long. It appears to be working just fine.
    Jake
    Thank you Jake!
    I am sorry, I have another question because I am a newbie! Now I try with the CFI Flash (I have a DE development board), but I have this error:
    Program failed at offset 146C6
    I do not know how to find the offset! In SOPC Builder, my CFI Flash is at the address 0x01400000 (it is put automatically here). What should I do?
    Thanks again, it is so nice to see a whole community of people helping each other!
    éléa
    Can you provide the full console printout from the flash programmer? This will tell us what base address the programmer is trying to program the flash at. My first guess is simply that your CFI flash is not connected properly.
    Jake
    To connect my CFI Flash I used a tri-state-bridge and the CFI component provided by Altera. I am working on a DE1 development board, can it be the problem? Should I use another component? I made the test of my memory with the template test memories provided also by Altera and then found my CFI Flash. Here is the screen I obtained:
    #!/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
    cd D:/Test_memoires/essai/Debug
    # Creating .flash file for the FPGA configuration
    "$SOPC_KIT_NIOS2/bin/sof2flash" --offset=0x0 --input="D:/Test_memoires/carte.sof
    " --output="carte.flash"
    Info: *******************************************************************
    Info: Running Quartus II Convert_programming_file
    Info: Command: quartus_cpf --no_banner --convert D:/Test_memoires/carte.sof cart
    e.rbf
    Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
    Info: Peak virtual memory: 58 megabytes
    Info: Processing ended: Fri Aug 07 08:22:08 2009
    Info: Elapsed time: 00:00:03
    Info: Total CPU time (on all processors): 00:00:03
    # Programming flash with the FPGA configuration
    "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00000000 --sidp=0x00505128
    --id=1155318747 --timestamp=1249570787 --instance=0 "carte.flash"
    Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
    Resetting and pausing target processor: OK
    Reading System ID at address 0x00505128: verified
    : Checksumming existing contents
    00000000 : Verifying existing contents
    00002000 : Verifying existing contents
    00004000 : Verifying existing contents
    00006000 : Verifying existing contents
    00008000 : Verifying existing contents
    0000A000 : Verifying existing contents
    0000C000 : Verifying existing contents
    0000E000 : Verifying existing contents
    00000000 : Reading existing contents
    00010000 : Reading existing contents
    00020000 : Reading existing contents
    00030000 : Reading existing contents
    00040000 : Reading existing contents
    00050000 : Reading existing contents
    00060000 : Reading existing contents
    00070000 : Reading existing contents
    Checksummed/read 101kB in 3.0s
    00000000 ( 0%): Erasing
    00010000 ( 1%): Erasing
    00020000 (15%): Erasing
    00030000 (29%): Erasing
    00040000 (43%): Erasing
    00050000 (57%): Erasing
    00060000 (71%): Erasing
    00070000 (85%): Erasing
    Erased 456kB in 3.8s (120.0kB/s)
    00000000 ( 0%): Programming
    00002000 ( 1%): Programming
    00004000 ( 1%): Programming
    00006000 ( 1%): Programming
    00008000 ( 1%): Programming
    0000A000 ( 1%): Programming
    0000C000 ( 1%): Programming
    0000E000 ( 1%): Programming
    00010000 ( 1%): Programming
    Program failed at offset 1431C
    # Creating .flash file for the project
    "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x00000000 --end=0x3fffff --reset=0x50400
    0 --input="essai.elf" --output="ext_flash.flash" --boot="C:/altera/90/ip/altera/
    nios2_ip/altera_nios2/boot_loader_cfi.srec"
    # Programming flash with the project
    --id=1155318747 --timestamp=1249570787 --instance=0 "ext_flash.flash"
    Empty flash content cannot be programmed or verified
    "$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --input="essai.elf" --output="epcs_contro
    ller.flash"
    "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00504000 --sidp=0x0
    0505128 --id=1155318747 --timestamp=1249570787 --instance=0 "epcs_controller.fla
    sh"
    Checksummed/read 30kB in 0.7s
    Erased 64kB in 0.9s (71.1kB/s)
    Programmed 35KB +29KB in 1.5s (42.6KB/s)
    Thanks for your help
    --- Quote Start ---
    avtx30, did you get this going? I'm having trouble reconfiguring and knowing in that load that I'm not in factory mode. Param 0 is always reading 0, not 1 after a reconfigure. Are you having any better luck than I am?
    Bill
    --- Quote End ---
    Hi Bill,
    I could read 1 after a reconfigure. The app. note no.521 was a good one, did you try it?
    --- Quote Start ---
    1 - You can use the remote update core to trigger a reconfiguration.
    2 - What I do for production ...
    . a - Install the Quartus II standalone programmer on the production PC.
    . b - Copy the following files from your development PC and package them with your programming files...
    . nios2-flash-programmer.exe
    . cygwin1.dll
    . jtag_atlantic.dll
    This should be all you need to run the nios2 flash programmer on the production PC. It's a whole lot faster than using the jtag indirect method with the quartus II programmer.
    Jake
    --- Quote End ---
    Hi, Jake
    Could you please describe how to use the remote update core to trigger a reconfiguration in detail? I mean that the remote update core is included in factory image. Therefore, how does the software of application image access the remote update core, since the application image is independent with factory image?
    Thank you in advance
    -wei
