17 years ago[HELP]question about loading different sof+elf files in remote upgrade
hello: I've completed the things about loading application sof file in remote upgrade and that is successful.Now I want to load the sof+elf file.How could i do?Can i use the ide flash programmer t...
14 years ago --- Quote Start --- 1 - You can use the remote update core to trigger a reconfiguration. 2 - What I do for production ... . a - Install the Quartus II standalone programmer on the production PC. . b - Copy the following files from your development PC and package them with your programming files... . nios2-flash-programmer.exe . cygwin1.dll . jtag_atlantic.dll This should be all you need to run the nios2 flash programmer on the production PC. It's a whole lot faster than using the jtag indirect method with the quartus II programmer. Jake --- Quote End --- Hi, Jake Could you please describe how to use the remote update core to trigger a reconfiguration in detail? I mean that the remote update core is included in factory image. Therefore, how does the software of application image access the remote update core, since the application image is independent with factory image? Thank you in advance -wei
