17 years ago[HELP]question about loading different sof+elf files in remote upgrade
hello: I've completed the things about loading application sof file in remote upgrade and that is successful.Now I want to load the sof+elf file.How could i do?Can i use the ide flash programmer t...
17 years ago --- Quote Start --- Programmed 200KB +56KB in 4.6s (55.6KB/s) Did not attempt to verify device contents Leaving target processor paused --- Quote End --- This is not an error. This is exactly what you should see. With an EPCS device, the flash programmer programs the data but does not read it back for verification simply because it takes so long. It appears to be working just fine. Jake
