Help!I lost my 'Pad View' Window!
I accidently dragged out the 'Group List' window from its original position when I was using the Pin Planner,and I cannot drag it back to where it used to be;what's worse,I cannot see the 'Pad View' window agian!
I even restalled the software and it still won't work. Can someone help me,please? I'm dying from this problem. Best regards!12 Replies
Yeah it's in the registry. I found it but I don't dare recommend how to manipulate it.
Jake - Altera_Forum
You are correct. They changed something in 9.0. I was using my 8.1 machine at home. I'll see if I can find the temp settings for 9.0.
Jake - Altera_Forum
--- Quote Start --- This is not true, at least for Pin planner. I've deleted the db sub-folder, but the Pin Planned and Pad View window remain to be displayed at the same place in my monitor. I think this settings are stored somethere in the windows register, but i can be wrong --- Quote End --- Me too.Except that I cannot the 'Pad View' window.I close all the List Windows;just the 'Top View' window remains in the screen.Then I close the current project and open a new one, compile it and check the 'Pin Planner'; as a result, the List Windows remain unselected. By the way, mine is version 9.0 - Altera_Forum
--- Quote Start --- This is not true, at least for Pin planner. I've deleted the db sub-folder, but the Pin Planned and Pad View window remain to be displayed at the same place in my monitor. I think this settings are stored somethere in the windows register, but i can be wrong --- Quote End --- Works on my machine. What version of the tools are you using? Jake - Altera_Forum
--- Quote Start --- For future reference; these temporary settings are actually stored in the project's "db" directory. Delete the "db" directory and everything goes back to the default. This is also why re-installing didn't solve your problem. They follow the project. --- Quote End --- This is not true, at least for Pin planner. I've deleted the db sub-folder, but the Pin Planned and Pad View window remain to be displayed at the same place in my monitor. I think this settings are stored somethere in the windows register, but i can be wrong - Altera_Forum
Jake - Altera_Forum
Definitively, this Pad View window is opened and is hidden somethere. But I don't know how to close it without clicking on it :-(
--- Quote Start --- I'm not sure I understand. Maybe you can attach a screenshot. Why can't you put the "Group List" window back where you want it. Also, if you click "View->Pad View" from within the pin planner, do you not get the "Pad View" window? Jake --- Quote End --- Question 1:Actually I've dragged it back now.I think it's just a matter of dragging skill. Question 2:No, I cannot get that.Actually I can see that the 'Pad View' button has been pressed, yet I cannot get the window.And I cannot undo the 'Pad View' button by re-clicking it, ie, I re-click the button; I cannot see the 'Pad View' window and the 'Pad View' button remains being pressed. - Altera_Forum
Thanks for all your attentions!
I've got an image of that situation. But I don't know how to upload it to Altera Forum,so I saved it in my gmail. Someone intrested please log in my gmail with 'UserName:LutherFreeman' and 'Keyword:123456789abcd';it's in the 'Sent Mail' item and titled "Lost Pad View". I believe it's OK not to look at the image;I just want to describe the situation clearly. In the image,you can see that the 'Pad View' button has been pressed;yet I cannot see the 'Pad View' window, nor could I undo the 'Pad View' button by re-click it. Does someone know another way to close the 'Pad View' window, besides by clicking the 'Pad View' button ?(If the window has been shut down, I won't see any image of it and the 'Pad View' button won't be pressed,right?) - Altera_Forum
The Pad View is a separate window from the Package View.
If the black dot is still there this means that your Pad View is opened and it is somethere. I suppose it is a floating window and you drag it somethere outside the Pin planner window and even outside boundaries of your monitor view so it is hidden for you. UL
