17 years agoHelp!I lost my 'Pad View' Window!
I accidently dragged out the 'Group List' window from its original position when I was using the Pin Planner,and I cannot drag it back to where it used to be;what's worse,I cannot see the 'Pad View' ...
17 years agoThe Pad View is a separate window from the Package View.
If the black dot is still there this means that your Pad View is opened and it is somethere. I suppose it is a floating window and you drag it somethere outside the Pin planner window and even outside boundaries of your monitor view so it is hidden for you. UL
