16 years agoHelp with startup
Hi guys,
I have a weird problem. In my current project I can run my code via RUN AS -> NIOS II HARDWARE. Everything is fine and the code works, but in this case you have to leave the USB-Blaster connected. Now I want to run my code without USB-Blaster. Has anybody an idea how to do that? When I flash my cfi and want to run the processor it doesn't work. FYI: The code runs out of cfi-flash. The reset vector points to the beginning of cfi-flash. The image for the fpga is stored in a epcs4 device. Thanks... Best regards ManuelNo RepliesBe the first to reply
