15 years agohelp with code
hey guys,
I am new at working with altera. I am learning to write code in vhdl at this moment. I have an assignment due tomorrow and I am having trouble with it. There is an error in my code and I cant figure out what it is. It show the following: Error (10500): VHDL syntax error at counter.vhd(49) near text "process"; expecting "if" This is my code: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.std_logic_arith.all; entity counter is port(clk :in std_logic; start :in std_logic; mode :in std_logic; count :buffer integer range 0 to 120; abcdefghijklmn :out std_logic_vector(13 downto 0)); end counter; architecture engine of counter is signal go :std_logic := '0'; signal sel :std_logic; begin process(start) begin if(start'event and start = '1')then go <= '1'; end if; end process; process(count) begin if (count = 0) then sel <= mode; end if; end process; process(go,count,clk,sel) begin if ((go = '0') or (count > 60)) then count <= 0; else if ((go = '1') and (clk'event and clk = '1')) then if (sel = '0') then count <= count + 5; else count <= count + 12; end if; end if; end process; end engine;2 Replies
omg, cannot believe i did not see that , thank you so much!!!!
--- Quote Start --- process(go,count,clk,sel) begin if ((go = '0') or (count > 60)) then count <= 0; else if ((go = '1') and (clk'event and clk = '1')) then if (sel = '0') then count <= count + 5; else count <= count + 12; end if; end if; end process; --- Quote End --- The 'else if' on the fifth line should be an 'elsif' (in one word).
