14 years agoHelp with CIC decimation filter
Hi, I wrote a Verilog code for a CIC decimation filter. I relied on a code written in the book 'digital signal processing with FPGA' . Here is the code: // cic decimation filter : R=64, M...
14 years agoNow that I have 5 posts, let me post the code and the simulation properly:
Code:
// cic decimation filter : R=64, M=1, N=3
module cicdecim64 (x_in,y_out,clk,reset);
input clk,reset;
input x_in;
output y_out;
parameter hold=0, sample=1;
reg state; //sample or hold states
reg count; //count till 63 starting from 0
reg x; //input
wire sx; //sign extended input
reg i0; //Integrator output section 0
reg i1; //output section 1 under the consideration of Haugenauer's pruning
reg i2;
reg i2d1, c1, c0; // Integrator+COMB 0
reg c1d1, c2;
reg c2d1, c3;
always @(negedge clk)
begin : FSM // finite state machine
case (state)
hold : begin
if (count<63) // setting states for downsampling
state <= hold;
else
state <=sample;
end
default:
state <= hold;
endcase
end
assign sx={{16{x}},x_in};
// Integrator
always @(posedge clk)begin
if(reset) begin
i0 <= 24'd0;
i1 <= 19'd0;
i2 <= 14'd0;
x <= 8'd0;
end
else
x <= x_in;
i0 <= i0+sx;
i1 <= i1+i0;
i2 <= i2+i1;
case (state) //downsample
sample : begin
c0 <= i2;
count <= 0; //reset counter once a sample has been fetched
end
default :
count <= count+1;
endcase
end
// COMB
begin: COMB
i2d1 <= c0;
c1 <= c0-i2d1;
c1d1 <= c1;
c2 <= c1-c1d1;
c2d1 <= c2;
c3 <= c2-c2d1;
end
assign y_out=c3;
endmodule
Test bench:
`timescale 1ns/1ps
module test;
reg clk,reset;
reg x;
wire y;
cicdecim64 cic (x,y,clk,reset);
initial begin
x <=8'd1;
clk<=1'b0;
reset <= 1'b0;# 4 reset=~reset;# 5 reset=~reset;
end
always# 4 clk=~clk;
endmodule
Simulation results: http://s10.postimage.org/5g5m5xop5/sim.png As u can see, reset is only resetting x and ignoring the others. http://postimage.org/image/71oahgce5/
