14 years agoHelp!!!!! SDRAM interface Cyclone III.
I have a poject with SDRAM. I can create a interface with 128 MB SDRAM (BOTTOM or TOP). but, i don't know how to use full 256 MB SDRAM (BOTTOM and TOP). I use SOPC Builder to create system. Can you h...
14 years agoTthanks a lot! I did it!
I added Ram onchip and check ok with "Hello world small". but the major problem is i can't still write or read into ddr2 sdram. i wonder i maped pins right? module lab06 ( clkin_50,clkin_125, cpu_resetn, ddr2bot_wen, ddr2bot_rasn, ddr2bot_casn, ddr2bot_cke, ddr2bot_csn, ddr2bot_odt, ddr2bot_a, ddr2bot_ba, ddr2bot_active, ddr2top_wen, ddr2top_rasn, ddr2top_casn, ddr2top_cke, ddr2top_csn, ddr2top_odt, ddr2top_a, ddr2top_ba, ddr2top_active, ddr2_dq, ddr2_dqs, ddr2_dm, ddr2_ck_p, ddr2_ck_n); output ddr2bot_active; output ddr2top_active; output [ 12: 0] ddr2bot_a; output [ 1: 0] ddr2bot_ba; output ddr2bot_casn; output ddr2bot_cke; output ddr2bot_csn; output ddr2bot_odt; output ddr2bot_rasn; output ddr2bot_wen; output [ 12: 0] ddr2top_a; output [ 1: 0] ddr2top_ba; output ddr2top_casn; output ddr2top_cke; output ddr2top_csn; output ddr2top_odt; output ddr2top_rasn; output ddr2top_wen; output [ 7: 0] ddr2_dm; inout [ 63: 0] ddr2_dq; inout [ 7: 0] ddr2_dqs; inout [ 2: 0] ddr2_ck_n; inout [ 2: 0] ddr2_ck_p; input clkin_50; input clkin_125; input cpu_resetn; nios_sys DUT ( // 1) global signals: .clk_125 (clkin_125), .clk_50 (clkin_50), .ddr2_bot_aux_full_rate_clk_out (), .ddr2_bot_aux_half_rate_clk_out (), .ddr2_bot_phy_clk_out (), .ddr2_top_aux_full_rate_clk_out (), .ddr2_top_aux_half_rate_clk_out (), .ddr2_top_phy_clk_out (), .reset_n (cpu_resetn), .sys_clk0 (), // the_LED_pio .out_port_from_the_LED ({ddr2top_active,ddr2bot_active}), // the_ddr_bot .global_reset_n_to_the_ddr2_bot (cpu_resetn), .local_init_done_from_the_ddr2_bot (), .local_refresh_ack_from_the_ddr2_bot (), .local_wdata_req_from_the_ddr2_bot (), .mem_addr_from_the_ddr2_bot (ddr2bot_a), .mem_ba_from_the_ddr2_bot (ddr2bot_ba), .mem_cas_n_from_the_ddr2_bot (ddr2bot_casn), .mem_cke_from_the_ddr2_bot (ddr2bot_cke), .mem_clk_n_to_and_from_the_ddr2_bot (ddr2_ck_n[0]),.mem_clk_to_and_from_the_ddr2_bot (ddr2_ck_p[0]), .mem_cs_n_from_the_ddr2_bot (ddr2bot_csn), .mem_dm_from_the_ddr2_bot (ddr2_dm [7:4]), .mem_dq_to_and_from_the_ddr2_bot (ddr2_dq [63:32]), .mem_dqs_to_and_from_the_ddr2_bot (ddr2_dqs [7:4]), .mem_odt_from_the_ddr2_bot (ddr2bot_odt), .mem_ras_n_from_the_ddr2_bot (ddr2bot_rasn), .mem_we_n_from_the_ddr2_bot (ddr2bot_wen), .reset_phy_clk_n_from_the_ddr2_bot (), // the_ddr_top .global_reset_n_to_the_ddr2_top (cpu_resetn), .local_init_done_from_the_ddr2_top (), .local_refresh_ack_from_the_ddr2_top (), .local_wdata_req_from_the_ddr2_top (), .mem_addr_from_the_ddr2_top (ddr2top_a), .mem_ba_from_the_ddr2_top (ddr2top_ba), .mem_cas_n_from_the_ddr2_top (ddr2top_casn), .mem_cke_from_the_ddr2_top (ddr2top_cke), .mem_clk_n_to_and_from_the_ddr2_top (ddr2_ck_n[1]),
.mem_clk_to_and_from_the_ddr2_top (ddr2_ck_p[1]), .mem_cs_n_from_the_ddr2_top (ddr2top_csn), .mem_dm_from_the_ddr2_top (ddr2_dm [3:0]), .mem_dq_to_and_from_the_ddr2_top (ddr2_dq [31:0]), .mem_dqs_to_and_from_the_ddr2_top (ddr2_dqs [3:0]), .mem_odt_from_the_ddr2_top (ddr2top_odt), .mem_ras_n_from_the_ddr2_top (ddr2top_rasn), .mem_we_n_from_the_ddr2_top (ddr2top_wen), .reset_phy_clk_n_from_the_ddr2_top (), // the_pll .locked_from_the_pll (), .phasedone_from_the_pll() ) ; endmodule
