14 years ago
Help on VHDL
Just want to design a mod-12 counter counting from 0 to 12, but when I use the following code, it always set q as 0 to 7 instead of 0 to 11 (Under QSim simulator).
Library ieee;
Use ieee.std_logic_1164.all;
Entity CounterTest is
port (cp, reset: in std_logic;
q: buffer integer range 0 to 64);
end CounterTest ;
Architecture logicfunction of CounterTest is
begin
process (reset, cp, q)
begin
if((reset = '0') OR (q > 11)) Then
q <= 0;
elsif (cp'Event AND cp='1') Then
q <= q + 1;
end if;
end process;
end logicfunction;
But if I change the following line in process from:
"if((n_rd = '0') OR (q > 11)) Then"
to
"if((n_rd = '0') OR (q >= 12)) Then"
or
"if((n_rd = '0') OR (q = 12)) Then"
Then it works fine under QSim simulator. Have not tried on real FPGA yet though.
Is there any thing wrong or I missed something?
    Thanks a lot. that is really the problem. I got the idea.
    --- Quote Start ---
    Rewrite the process this way:
    begin
    if (reset = '0')
    q <= 0;
    if (q > 11) Then
    q <= 0;
    else
    q <= q + 1;
    endif;
    end if;
    end process;
    Otherwise the q>11 condition would be synthesized with combinatorial logic and it will lead to impredictable behaviour on real hardware, since q bits don't switch at the same time.
    For example, from 7 (binary 0111) to 8 (1000) you can have a transitional status like 1111 or 1101, which is >11 and would reset your counter.
    --- Quote End ---
    begin
    if (reset = '0')
    q <= 0;
    if (q > 11) Then
    q <= 0;
    else
    q <= q + 1;
    endif;
    end if;
    end process;
