14 years agoHelp on VHDL
Just want to design a mod-12 counter counting from 0 to 12, but when I use the following code, it always set q as 0 to 7 instead of 0 to 11 (Under QSim simulator). ================================...
14 years agoThanks a lot. that is really the problem. I got the idea.
--- Quote Start --- Rewrite the process this way: process (reset, cp, q) begin if (reset = '0') q <= 0; elsif (cp'Event AND cp='1') Then if (q > 11) Then q <= 0; else q <= q + 1; endif; end if; end process; Otherwise the q>11 condition would be synthesized with combinatorial logic and it will lead to impredictable behaviour on real hardware, since q bits don't switch at the same time. For example, from 7 (binary 0111) to 8 (1000) you can have a transitional status like 1111 or 1101, which is >11 and would reset your counter. --- Quote End ---
