FredcwGO_BR
2 years agoHelp on understanding HDL module "always" clock transitions
Howdy all, I'm a newbee on FPGA, and needing to use QuartusII 13.0.1 for this is the EPM7128 board that i have. The following code compiles but simulation does not show what i expected. In...
- 2 years ago
it's the design concept.
The condition if( xcount2[10:0] == 11'd433 ) can't produce constant frequency, evenly spaced events when applied to the 15 bit baud rate counter.
You can however easily achieve waht you want by slightly rearrangind the design:1. have a 115k2 tic counter producing you constant frequency tic.
2. divide the 115k2 tic down according to select baud rate, fortunately they involve integer frequency ratios.
Your time constants are 1 clock period off, by the way.
TingJiangT_Intel
Contributor
2 years agoWe recommend you to assign the initial value via 'always' block with reset signal instead of 'initial'. As 'initial' is unsynthesizable.
