16 years agohelp! msel select, cyclone iii
hi,all.
i use the ep3c10e144c8n and epcs16. i set the msel scheme to 100. VCCIO of the banks in which the configuration pins reside is 3.3V. the EPCS16 used is powered by 3.3V according to the quartus ii, i can download the programme to the ecps. But it can't configure the fpga. and i also want to know the mean of "Configuration Voltage Standard" in the datasheet. The power of the epcs and VCCIO of the banks in which the configuration pins ?1 Reply
MSEL pins must be connected to 2.5V. NOT 3.3V
The other pins are 3.3V
