17 years agohelp me to translate verilog to vhdl
hello,
is there anyone expert in both verilog and vhdl?? i did learn only vhdl..help me to translate these codes into vhdl.. `timescale 1ns / 1ps module mctrl( input clk, input rst, output [31:0] wb_o_dat, output wb_o_ack, input [31:0] wb_i_adr, input [3:0] wb_i_sel, input wb_i_we, input [31:0] wb_i_dat, input wb_i_cyc, input wb_i_stb, output wb_o_err, inout [31:0] GPIO, input [31:0] GPIO_I ); wire sel_ram; wire sel_rom; wire sel_io; wire sel_ddr; localparam RAM_BITS=11; localparam ROM_BITS=14; localparam IO_BITS=16; wire [RAM_BITS-1:0] ram_addr; wire [ROM_BITS-1:0] rom_addr; wire [IO_BITS-1:0] io_addr; wire [31:0] ramdata; wire [31:0] romdata; wire [31:0] iodata; wire ram_ack_o; wire rom_ack_o; wire io_ack_o; wire rom_err; wire io_err; wb_bram# ( .ASIZE(RAM_BITS) ) my_ram ( .clk ( clk ), .rst ( rst ), .ce ( sel_ram ), .we ( wb_i_we ), .addr( ram_addr ), .dati( wb_i_dat ), .dato( ramdata ), .ack ( ram_ack_o ) ); wb_prom my_rom ( .clk ( clk ), .rst ( rst ), .we ( wb_i_we ), .ce ( sel_rom ), .addr( rom_addr ), .dato( romdata ), .dati ( wb_i_dat ), .ack ( rom_ack_o ) ); wb_io my_io ( .clk ( clk ), .rst ( rst ), .ce ( sel_io ), .we ( wb_i_we ), .addr ( io_addr ), .dato ( iodata ), .dati ( wb_i_dat ), .ack (io_ack_o), .err ( io_err ), .mask ( wb_i_sel ), .GPIO ( GPIO ), .GPIO_I ( GPIO_I ) ); reg ack_int; assign ram_addr = wb_i_adr[RAM_BITS-1:0]; assign rom_addr = wb_i_adr[ROM_BITS-1:0]; assign io_addr = wb_i_adr[IO_BITS-1:0]; wire op; assign op = wb_i_cyc && wb_i_stb; assign sel_ram = op && (wb_i_adr[31:30] == 2'b11); assign sel_rom = op && (wb_i_adr[31:30] == 2'b00); assign sel_io = op && (wb_i_adr[31:30] == 2'b01); assign wb_o_dat = sel_ram ? ramdata : sel_rom ? romdata : iodata; assign wb_o_ack = ram_ack_o | rom_ack_o | io_ack_o; assign wb_err_o = 0; // synthesis translate_off always @(posedge clk) begin if (wb_i_we && sel_rom && wb_i_adr[31:5] != 0) begin $display("%t: Invalid write to ROM: Address %h\n", $time, wb_i_adr[12:0]); $stop; end end // synthesis translate_on endmodule12 Replies
because this code is written by other people and i do understand very little from verilog. thats why i want to convert it into vhdl because i can understand..
Why do you want to translate this code into VHDL? You may use it in Quartus II together with VHDL modules with no translation required. I have used mixed VHDL-Verilog implementation sometimes, and everything works well in Quartus.
