16 years agoHelp me about measure clock on osciloscope.
Hi everyone, I have project on board DE2. I use PLL in megafunction to create the clock 500MHz from 50MHz. Then i use clock counter to decrease the clock from 500MHz to clock_out 250KHz, 125KHz, 6...
16 years agobutxarakham.nh2008
you should first learn and use the TimeQuest tool in your design. After this you have to certify if you are using the correct bank of I/O (if this clock is permitted for this family). sds[]
