16 years agoHelp me about measure clock on osciloscope.
Hi everyone, I have project on board DE2. I use PLL in megafunction to create the clock 500MHz from 50MHz. Then i use clock counter to decrease the clock from 500MHz to clock_out 250KHz, 125KHz, 6...
16 years agoI tested my design , 500MHz my design failed, but smaller 250MHz is ok.
I also mapped clock_out to the LEDR[0] for testing, when i use switch to change clock_out the LEDR[0], the speed blink of LED also changed, it proved that the clock_out had change. "Did it pass timing requirements?" -> what u mean? require on osci or on design.:d
