15 years ago
help in for loop
sir,here is my small code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity nu is
Port ( ---a : in STD_LOGIC_VECTOR (6 downto 0);
b : out STD_LOGIC_VECTOR (6 downto 0));
end nu;
architecture Behavioral of nu is
constant f : std_logic_vector(7 downto 0) :="01011001";
signal result : integer;
begin
k1 : for i in 0 to 4 generate
result <= conv_integer(signed(f))*i;
b <= conv_std_logic_vector(result,7);<--- error in this line.
end generate;
end Behavioral;
Analyzing Entity <nu> in library <work> (Architecture <Behavioral>).
ERROR:Xst:800 - "C:/.Xilinx/gateor/float.vhd" line 44: Multi-source on Integers in Concurrent Assignment.
plz fix my problem.
    In that case at least you need input clock. Then run a counter from 0 to 4 (as integer) and multiply by your internal constant.
    However, this will do as a crude exercise since you might just precompute result on paper and then don't need the design.
    sir i want to multiply a 8 bit number with 0,1,2,3,4.but don't understand how to keep them in output using for loop.:(
    --- Quote Start ---
    end generate;
    --- Quote End ---
    A common misunderstanding of HDL loops:
    Your loop is unrolled at compile time to:
    result <= conv_integer(signed(f))*0;
    result <= conv_integer(signed(f))*1;
    result <= conv_integer(signed(f))*2;
    result <= conv_integer(signed(f))*3;
    result <= conv_integer(signed(f))*4;
    so bothe result and b are driven by multiple statements. If loop was in a sequential body then last statement overrides and even then it becomes meaningless.
    You better tell us what do you want to do.
    you have assigned to b 5 times.
    secondly this is an altera forum, you are using xilinx tools
