15 years agohelp in for loop
sir,here is my small code library IEEE; use IEEE.STD_LOGIC_1164.ALL; use ieee.std_logic_unsigned.all; use ieee.std_logic_arith.all; -- Uncomment the following library declaration if usin...
15 years ago --- Quote Start --- k1 : for i in 0 to 4 generate result <= conv_integer(signed(f))*i; b <= conv_std_logic_vector(result,7);<--- error in this line. end generate; --- Quote End --- A common misunderstanding of HDL loops: Your loop is unrolled at compile time to: result <= conv_integer(signed(f))*0; b <= conv_std_logic_vector(result,7); result <= conv_integer(signed(f))*1; b <= conv_std_logic_vector(result,7); result <= conv_integer(signed(f))*2; b <= conv_std_logic_vector(result,7); result <= conv_integer(signed(f))*3; b <= conv_std_logic_vector(result,7); result <= conv_integer(signed(f))*4; b <= conv_std_logic_vector(result,7); so bothe result and b are driven by multiple statements. If loop was in a sequential body then last statement overrides and even then it becomes meaningless. You better tell us what do you want to do.
