JEL_W's avatar
JEL_W
7 years ago
Hello everyone, I need your help I'm using ADC AD9254 and DAC 5672, with FPGA DE10 standard, I want to acquire data, so Implement this code: the data out is associated to The dac, I get the result below:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY work;
ENTITY Co IS
port (clk: in std_logic;
reset: in std_logic;
DCO: in std_logic;
Data_valid: out std_logic;
Data_in: in std_logic_vector(13 downto 0);
Data_out: out std_logic_vector (13 downto 0)
end;
architecture Co_arch of Co is
signal count : std_logic_vector(13 downto 0);
begin
process(clk,reset)
begin
if reset='1' then
count<= (others=>'Z');
elsif rising_edge(Clk) then
if DCO='1' then
count<=Data_in;
Data_valid<='1';
else
Data_valid<='0';
end if;
end if;
Data_out<= count;
end process;
end Co_arch;
  • IDeyn's avatar
    IDeyn
    Hi JEL W,
    It looks like you missed a sign, either in code or in DAC or ADC settings, where you probably need to choose two's complement instead of offset binary which is chosen by default.
    Ivan
  • JEL_W's avatar
    JEL_W
    Hi
    I sent a sinusoidal signal through low frequency generator to ADC , but I didn't manage to get the same signal at the output of DAC,
    I get an inversed signal, the question is how can I obtain the same signal, Did I miss something in the code ?
    Thank you
    • corestar's avatar
      corestar
      Is your DAC exepcecting signed or straight binary. Same for the ADC. What you are seeing is almost right and very common when there is a signed unsigned conflict. For example, if your ADC is returning a signed number, but your DAC expects straight binary, but you fail to offset it, you will see something like what you show.
