HDMI example design errors with Agilex 7
Hi dncmrc1 ,
May I know which quartus version that you are trying ?
I lay down some of the suggestion in order to help you to move a step forward.
1. Create a project targeted the device OPN that you need, for example, in this case, you need to select your targeted devkit
2. Select HDMI from the IP Catalog
3. On the Target Development Kit "Select Board" option, choose "Customer Development Kit" and click on Generate Example Design
After generation finishes, open the QSF file, there are some of the set_location_assignments with "Your_location" that needs to be updated.
You can refer to the the design example (since the devkits are the same) and copy over the setting: (FOR YOUR REFERNCE PURPOSE ONLY)
The error you seeing might due to clock and pin type mis-matching
Do carefully checking each pin carefully https://www.altera.com/design/devices/resources/pinouts#tab-blade-1-3
Wincent
Thank you. I found the solution to my issue (I was missing to include one of the demo scripts).
You can close this SR.
