9 years agoHardening an IP
I am in the need of hardening an IP, which can be used for final integration into the chip level netlist(vqm) and then generate the programming files(JIC). Right now i am always reading the source files of the IP with the VQM of the final chip netlist, which is more time consuming. I can do a VQM of the IP and use it with the chip level VQM, instead i was wondering if i could create a hard logic partition of the IP and re use it always. Please share your ideas if there are better ways of implementing. Thanks in advance. Regards, Srinivas1 Reply
You can create a partition for your IP and export it as a post-fit netlist. This way it will always be placed on the same LUTs every time, so as long as this is acceptable then you can try that.
This can make fitting other parts harder as it gives them less scope to move around to fix their timing, but it means this IP should always meet timing.
