16 years agoGood progress on UART
I have my Uart Working, but not perfectly, GPGGA comes from the GPS chip once a second, about every 5 seconds my UART reads it perfeclty giving my Time and position, any sugestions how to fine tune t...
16 years agoI need your help to figure out how to connect the PC RS232 to the NIOS UART on a C III starter board. I have a daughter card that exposes the FPGA pins, so I have access physically to ALL I/O pins, Also 5 V and 3.3 V pins on that card. I also have a RS232 to TTL tiny external board that is connected to the PC Serial cable, and has 4 pins as output. The four pins are Power, GND, Tx and Rx. I tried to connect the Tx and Rx to their perspective equal Rx and Tx in the NIOS (pin assignment is correct) after I added the RS232 UART in the nios using SOPC builder, with no flow control.
I cannot send or receive on either sides, I mean Nios running c code cannot read or write, the function call stuck. Also on the PC the c code cannot read or write it does also stuck on the function call. I am using ANSI standard C code for fopen, fgetc, fputc, etc.. Can you help me please to find out how to connect the PC to the UART on the FPGA? I appreciate it. Thanks.
