10 years ago
Global, Local, Regional, and Peripheral clocks
Hi All,
How can I know what pins could be used as the Global, Local, Regional, and Peripheral clocks in the ArriaV device (as an example)? What difference between these clocks? Where to read about (manual/tutorial/userguide)?
Thank you!
    Probably the Fitter make such a route to meet timing requirement .
    Is every device pin/pad has an attached Global Clock Buffer? I had a design where the Fitter went to another rib of the device to pick up a Global Clock buffer there... Why did it do so? How to avoid such route "travelling"?
    What's the difference between the Local, Regional, and Peripheral clocks? Are there another clock types (besides Global)?
    Cannot find the ATLCLKCTRL IP in the IP-Catalog... I'm using the Quartus-II v15.0. Where should I see for this IP? Thank you
    Hi dmitryl,
    As far as I know you can use any pin as global, local, regional or peripheral clock when you use Altera's ATLCLKCTRL IP block. The IP block allows you to "promote" a certain signal to travel over dedicated spines, e.g. the global spine which covers the entire FPGA, or a local clock spine, which covers only certain area of the FGPA etc.
    Regards, Richard.
