10 years agoGlobal, Local, Regional, and Peripheral clocks
Hi All, How can I know what pins could be used as the Global, Local, Regional, and Peripheral clocks in the ArriaV device (as an example)? What difference between these clocks? Where to read ab...
10 years agoHi dmitryl,
As far as I know you can use any pin as global, local, regional or peripheral clock when you use Altera's ATLCLKCTRL IP block. The IP block allows you to "promote" a certain signal to travel over dedicated spines, e.g. the global spine which covers the entire FPGA, or a local clock spine, which covers only certain area of the FGPA etc. Regards, Richard.
