Thulasi's avatar
Thulasi
2 months ago
Global Clock & Regional clock inputs in Agilex M FPGA
Hi, Kindly answer the following queries related to reference clocks in F-Tile of Agilex M FPGA. Why F-Tile in Agilex M series FPGA needs four Global Clock input signals & Four regional clock input...
  • Ash_R_Altera's avatar
    Ash_R_Altera
    1 month ago
    Based on the F-tile architecture and the SyncE operation.
    1. Is SyncE clock recovery supported only on the FGT PMAs in Quad-2 and Quad-3?
    Yes. The SyncE section says the recovered clock from the FGT PMA can be driven to dedicated clock output pins, and that each F-Tile has only two such outputs: FGT Quads 2 and 3. The architecture guide further says one RX CDR clock output must come from Quad 2 and the other from Quad 3.
    2. Is it not possible to recover the SyncE clock from transceivers in Quad-0 and Quad-1?
    Correct for the dedicated SyncE recovered-clock output path. Public docs say the “Enable dedicated CDR clock output” option is available only for Ports 8–15, which map to FGT Quads 2 and 3, not Quads 0 and 1.
    3. Is SyncE clock recovery supported on FHT PMAs, or only FGT PMAs?
    Based on the public F-Tile docs, it is only documented for FGT PMAs. The Ethernet SyncE chapter and the architecture chapter both describe FGT RX CDR clock output; the FHT clocking chapter describes FHT reference-clock inputs/common PLLs, not a corresponding SyncE recovered-clock output path.
    4. Which F-Tile transceiver types and quads support SyncE clock recovery?
    • Supported for SyncE recovered-clock output: FGT, Quad 2 and Quad 3 only.
    • Not supported for that output path: FGT Quad 0/1 and FHT PMAs.
    Refer: https://docs.altera.com/r/docs/683872/26.1/f-tile-architecture-and-pma-and-fec-direct-phy-ip-user-guide/fgt-and-system-pll-reference-clock-network
    https://docs.altera.com/r/docs/683023/25.3.1/f-tile-ethernet-hard-ip-user-guide/clock-connections-in-synchronous-ethernet-operation
