14 years agogigabit ethernet
For a Cyclone IV: Does Gigabit ethernet need to be implemented using transceivers, or can it be implemented using the normal IO pins? The PHY that was selected for this implementation has four separa...
14 years agoThere is absolutely no problem driving a GMII/RGMII interface with a Cyclone IV, using LVCMOS DDR I/O, and any pin can be used for them. If possible it is better to use a dedicated clock input for the receive clock as it will make meeting timing requirements easier. You can also use a pll output pin for the transmit clock but I don't think it's absolutely necessary.
The cyclone iii development kit (http://www.altera.com/products/devkits/altera/kit-cyc3.html) uses a RGMII interface to a Marvel PHY, you can have a look at the schematic to see how they did it.
