11 years agoget_rtl_cells seems returns incomplete list of cells
Dear Forum,
I'm writing script to get list of rtl cells using following scheme: execute_module -tool map execute_module -tool fit set fullcollection [get_rtl_cells -hierarchical -nocase *] foreach_in_collection cell $cell_list { set type [get_rtl_cell_info -type $cell] puts -nonewline $cell puts -nonewline " - " puts "[get_rtl_cell_info -name $cell] - type: $type" } The resulting output is the following: cell_0 - Decoder0 - type: DECODER cell_4 - out - type: MUX cell_5 - in - type: IO cell_6 - sel[0] - type: IO cell_7 - sel[1] - type: IO cell_8 - out[0] - type: IO cell_9 - out[1] - type: IO cell_10 - out[2] - type: IO cell_11 - out[3] - type: IO When using Tools->Netlist Viewers->RTL Viewer I have found that there is actually 4 instances of MUX (out~0....out~4). How to get these instances? Verilog code: module DeMux_4x2 (in, sel, out); input in; input [1:0] sel; output [3:0] out; reg [3:0] out; always @(sel or in) begin case(sel) 2'b00: out <= {3'b000, in}; 2'b01: out <= {2'b00, in, 1'b0}; 2'b10: out <= {1'b0, in, 2'b00}; 2'b11: out <= {in, 3'b000}; endcase end endmodule2 Replies
I'm guessing the RTL "under the hood" is a single mux but the RTL viewer draws it as one per bit. What are you trying to do? I've never used get_rtl_cells or found a reason to and wonder if there's another way.
--- Quote Start --- I'm guessing the RTL "under the hood" is a single mux but the RTL viewer draws it as one per bit. What are you trying to do? I've never used get_rtl_cells or found a reason to and wonder if there's another way. --- Quote End --- Actually I'm trying to analyze and understand how the rtl view got constructed by the synthes tool. From above example you can see that my verilog is doing simple demux which after syntheses transformed to one decoder and 4 muxes. By calling get_rtl_cells I didn't get all instances of the mux, it only gave 1 of them. Please note that in the cell-id's there are missing 3 id's for those instances: cell_0 cell_1 cell_2 cell_3 cell_4 Why I'm not getting cell_1.. cell_3? And how the RTL Netlist View tool in the Quartus determines this?
