Balerion
1 year agoGeneric Quad SPI Controller-2 MT25QL01GBBB8E12 Write Problem.
Hi all, I have a custom board which has two MT25QL01GBBB8E12-0SIT flash on it. One is connected to EPCQ Controller. In this one, I am using the Public API functions inside altera_epcq_controller.h a...
Farabi_Altera
1 year agoHello,
Few things you can check/do:
1- Ensure WEL(Write Enable Latch) is set.
2- It is common practice to Erase the Flash before you perform flash write.
3- Verify the flash controller configuration is matching flash requirements :
i- clock frequency
ii- dummy clock cycles, address etc.
regards,
Farabi
