Generation Of VCCRCORE for Agilex FPGA
Can we directly use the same supply for VCCRCORE and VCCIO_PIO when we have only 1.2V supplies but some IO banks have non DDR4 io standards. (True Differential Inputs , 1.2V TTL outputs /Inputs).
According to following page :
For VCCRCORE we see the following statement. ` Share with VCCIO_PIO when I/O is 1.2V`
In Intel Agilex Review worksheet we see
`Transceiver core power supply. For use in Intel Agilex production devices only (placed here for migration purposes).
Connect the VCCRCORE to 1.2 V power supply.
You have the option to source VCCRCORE from the same regulator as VCCIO_PIO only when you are using the DDR4 I/O standard with proper isolation filtering.`
Do you have a specification/ example for proper isolation filtering. Can we get any other supply as a reference for filtering circuit?
Would recommend you to check various Agilex Devlopment kits available. The installers for each of them provides you with useful documents like schematics, BOM etc.
Refer to the link:
Intel® Agilex™ FPGA Development Kits and Development Board | Intel
Also check the Pin Connection Guidelines for Agilex https://www.intel.com/content/www/us/en/docs/programmable/683112/current/device-family-pin-connection-guidelines.html
1 Reply
- Ash_R_Altera
Refer to the link:
