13 years agoGenerating a signal with noise
What i am doing is i am trying to do is add random numbers to a signal to find PSD later. I wrote a code for random numbers generator which is working fine shown below:
LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY random IS ------> Interface GENERIC (n : INTEGER := 32); -- Input bit width PORT( clk : IN STD_LOGIC; random_num : OUT STD_LOGIC_VECTOR (n-1 DOWNTO 0) ); END random; ARCHITECTURE Behavioral of random is BEGIN PROCESS(clk) VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0) := (n-1 => '1' , OTHERS => '0'); VARIABLE temp : STD_LOGIC := '0'; BEGIN IF(RISING_EDGE(clk)) THEN temp := rand_temp(n-1) XOR rand_temp(n-2); rand_temp(n-1 DOWNTO 1) := rand_temp(n-2 DOWNTO 0); rand_temp(0) := temp; END IF; random_num <= rand_temp; END PROCESS; END; After that i tried to add the random signal to a known signal to get a new signal so i can find PSD. I wrote a code for that and i am getting some errors. The code is PACKAGE n_bit_int IS-- User-defined type SUBTYPE BITS32 IS INTEGER RANGE -2**32 TO 2**32-1; -- -256 ~255 SUBTYPE BITS33 IS INTEGER RANGE -2**33 TO 2**33-1; -- -512 ~511 END PACKAGE n_bit_int; LIBRARY WORK; USE WORK.n_bit_int.ALL; LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.MATH_REAL.ALL; ENTITY cumulants IS GENERIC (n : INTEGER := 32); PORT( clk : IN STD_LOGIC; x0 : IN BITS32; x1 : IN BITS32; x2 : IN BITS32; x3 : IN BITS32; y0 : OUT BITS33; y1 : OUT BITS33; y2 : OUT BITS33; y3 : OUT BITS33 ); END ENTITY cumulants; ARCHITECTURE Behavioral of cumulants is COMPONENT random PORT( clk : IN STD_LOGIC; random_num : OUT STD_LOGIC_VECTOR (n-1 DOWNTO 0) ); END COMPONENT random; BEGIN PROCESS VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0); BEGIN u1 : PORT MAP ( clk => clk1, random => rand_temp ); y0 <= x0 + rand_temp; y1 <= x1 + rand_temp; y2 <= x2 + rand_temp; y3 <= x3 + rand_temp; END PROCESS; END; The errors are Error (10500): VHDL syntax error at cumulants.vhd(49) near text "PORT"; expecting "(", or an identifier ("port" is a reserved keyword), or a sequential statement Error (10500): VHDL syntax error at cumulants.vhd(49) near text ";"; expecting ":=", or "<=" Please help me. Where am i going wrong.22 Replies
Hi DAVE
I am trying to find the mean and variance for random generating function code shown below. I know how to calculate practically but not able to implement it can you please help me.. LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.NUMERIC_STD.ALL; USE IEEE.STD_LOGIC_SIGNED.ALL; ENTITY random IS ------> Interface GENERIC (n : INTEGER := 16); -- Input bit width PORT( clk : IN STD_LOGIC; random_num : OUT STD_LOGIC_VECTOR(n-1 DOWNTO 0); random_sum: OUT STD_LOGIC_VECTOR(n-1 DOWNTO 0) ); END random; ARCHITECTURE Behavioral of random is BEGIN PROCESS(clk) VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0) := (n-1 => '1' , OTHERS => '0'); VARIABLE temp : STD_LOGIC := '0'; VARIABLE sum : STD_LOGIC_VECTOR(n-1 DOWNTO 0) :=( OTHERS => '0'); BEGIN IF(RISING_EDGE(clk)) THEN temp := rand_temp(n-1) XOR rand_temp(n-2); rand_temp(n-1 DOWNTO 1) := rand_temp(n-2 DOWNTO 0); rand_temp(0) := temp; sum := sum + rand_temp; END IF; random_num <= rand_temp; random_sum <= sum; END PROCESS; END; --ADI - Altera_Forum
Hi dave
I think i got where i went wrong..if i have any problem i ll ask for you help. thanks Aditya...:) - Altera_Forum
Hi dave
Thanks for the advice. I worked on the code and the output i am expecting is sum on input and random noise but i am getting what ever input i give as output. Here is the code LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.NUMERIC_STD.ALL; ENTITY cumulants IS GENERIC (n : INTEGER := 32); PORT( clk : IN STD_LOGIC; x : IN STD_LOGIC_VECTOR (n-1 DOWNTO 0); y : OUT STD_LOGIC_VECTOR (n-1 DOWNTO 0) ); END ENTITY cumulants; ARCHITECTURE Behavioral of cumulants is COMPONENT random PORT( clk : IN STD_LOGIC; random_num : OUT STD_LOGIC_VECTOR (n-1 DOWNTO 0) ); END COMPONENT random; SHARED VARIABLE rand_temp1 : STD_LOGIC_VECTOR(n-1 DOWNTO 0); SIGNAL s : INTEGER; BEGIN u1 : random PORT MAP ( clk => clk, random_num => rand_temp1 ); PROCESS(clk) BEGIN IF(RISING_EDGE(clk)) THEN y <= x OR rand_temp1 ; END IF; END PROCESS; END; The code for random number is shown above any help would be appreciated Aditya - Altera_Forum
You need to find yourself a good VHDL book.
Your code does not need the keywords 'PROCESS', 'BEGIN', 'END PROCESS', since you have not created any code that needs to go in the process. For type conversion, you need to look at what the numeric_std library provides. Hint: to_integer, but it takes an unsigned, so you need to figure out how a std_logic_vector gets converted to unsigned, and then convert unsigned to integer. Your code will look like s <= to_integer(<something here>(rand_temp)); I don't want to spoil your chance to learn by giving you all the details, so please search around and try to figure it out. Cheers, Dave - Altera_Forum
Hi dave thanks for the reply
PACKAGE n_bit_int IS-- User-defined type SUBTYPE BITS32 IS INTEGER RANGE -2**32 TO 2**32-1; -- -256 ~255 SUBTYPE BITS33 IS INTEGER RANGE -2**33 TO 2**33-1; -- -512 ~511 END PACKAGE n_bit_int; LIBRARY WORK; USE WORK.n_bit_int.ALL; LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.NUMERIC_STD.ALL; ENTITY cumulants IS GENERIC (n : INTEGER := 32); PORT( clk : IN STD_LOGIC; x0 : IN BITS32; x1 : IN BITS32; x2 : IN BITS32; x3 : IN BITS32; y0 : OUT BITS33; y1 : OUT BITS33; y2 : OUT BITS33; y3 : OUT BITS33 ); END ENTITY cumulants; ARCHITECTURE Behavioral of cumulants is COMPONENT random PORT( clk : IN STD_LOGIC; random_num : OUT STD_LOGIC_VECTOR (n-1 DOWNTO 0) ); END COMPONENT random; VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0); SIGNAL s : INTEGER; BEGIN u1 : random PORT MAP ( clk => clk, random_num => rand_temp ); PROCESS BEGIN s <= CONV_INTEGER(rand_temp); y0 <= x0 + s; y1 <= x1 + s; y2 <= x2 + s; y3 <= x3 + s; END PROCESS; END; I am getting an error as Error (10482): VHDL error at cumulants.vhd(49): object "CONV_INTEGER" is used but not declared is my deceleration of conversation bad? can you suggest me how i can improve my vhdl skills?? --:) ADI - Altera_Forum
Move u1 out of the process.
Guys i corrected my mistake and here is the code
PACKAGE n_bit_int IS-- User-defined type SUBTYPE BITS32 IS INTEGER RANGE -2**32 TO 2**32-1; -- -256 ~255 SUBTYPE BITS33 IS INTEGER RANGE -2**33 TO 2**33-1; -- -512 ~511 END PACKAGE n_bit_int; LIBRARY WORK; USE WORK.n_bit_int.ALL; LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.MATH_REAL.ALL; ENTITY cumulants IS GENERIC (n : INTEGER := 32); PORT( clk : IN STD_LOGIC; x0 : IN BITS32; x1 : IN BITS32; x2 : IN BITS32; x3 : IN BITS32; y0 : OUT BITS33; y1 : OUT BITS33; y2 : OUT BITS33; y3 : OUT BITS33 ); END ENTITY cumulants; ARCHITECTURE Behavioral of cumulants is COMPONENT random PORT( clk : IN STD_LOGIC; random_num : OUT STD_LOGIC_VECTOR (n-1 DOWNTO 0) ); END COMPONENT random; BEGIN PROCESS VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0); BEGIN u1 : random PORT MAP ( clk => clk, random_num => rand_temp ); y0 <= x0 + rand_temp; y1 <= x1 + rand_temp; y2 <= x2 + rand_temp; y3 <= x3 + rand_temp; END PROCESS; END; Now i am getting a new errors Error (10500): VHDL syntax error at cumulants.vhd(49) near text "PORT"; expecting "(", or "'", or "." Error (10500): VHDL syntax error at cumulants.vhd(49) near text ";"; expecting ":=", or "<=" Is there anything i am missing because i don't think i am. - Altera_Forum
How that was very help full dave..Thanks
Thanks for that man..
additionally, the cookbook (http://www.altera.com/literature/manual/stx_cookbook.pdf) demonstrates a way to use a ring oscillator to generate randomness
