13 years agoGenerating a signal with noise
What i am doing is i am trying to do is add random numbers to a signal to find PSD later. I wrote a code for random numbers generator which is working fine shown below: LIBRARY ieee; USE ie...
13 years agoGuys i corrected my mistake and here is the code
PACKAGE n_bit_int IS-- User-defined type SUBTYPE BITS32 IS INTEGER RANGE -2**32 TO 2**32-1; -- -256 ~255 SUBTYPE BITS33 IS INTEGER RANGE -2**33 TO 2**33-1; -- -512 ~511 END PACKAGE n_bit_int; LIBRARY WORK; USE WORK.n_bit_int.ALL; LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.MATH_REAL.ALL; ENTITY cumulants IS GENERIC (n : INTEGER := 32); PORT( clk : IN STD_LOGIC; x0 : IN BITS32; x1 : IN BITS32; x2 : IN BITS32; x3 : IN BITS32; y0 : OUT BITS33; y1 : OUT BITS33; y2 : OUT BITS33; y3 : OUT BITS33 ); END ENTITY cumulants; ARCHITECTURE Behavioral of cumulants is COMPONENT random PORT( clk : IN STD_LOGIC; random_num : OUT STD_LOGIC_VECTOR (n-1 DOWNTO 0) ); END COMPONENT random; BEGIN PROCESS VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0); BEGIN u1 : random PORT MAP ( clk => clk, random_num => rand_temp ); y0 <= x0 + rand_temp; y1 <= x1 + rand_temp; y2 <= x2 + rand_temp; y3 <= x3 + rand_temp; END PROCESS; END; Now i am getting a new errors Error (10500): VHDL syntax error at cumulants.vhd(49) near text "PORT"; expecting "(", or "'", or "." Error (10500): VHDL syntax error at cumulants.vhd(49) near text ";"; expecting ":=", or "<=" Is there anything i am missing because i don't think i am.
