13 years ago
Generating a signal with noise
What i am doing is i am trying to do is add random numbers to a signal to find PSD later. I wrote a code for random numbers generator which is working fine shown below:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY random IS ------> Interface
GENERIC (n : INTEGER := 32); -- Input bit width
PORT( clk : IN STD_LOGIC;
random_num : OUT STD_LOGIC_VECTOR (n-1 DOWNTO 0)
END random;
ARCHITECTURE Behavioral of random is
BEGIN
PROCESS(clk)
VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0) := (n-1 => '1' , OTHERS => '0');
VARIABLE temp : STD_LOGIC := '0';
BEGIN
IF(RISING_EDGE(clk)) THEN
temp := rand_temp(n-1) XOR rand_temp(n-2);
rand_temp(n-1 DOWNTO 1) := rand_temp(n-2 DOWNTO 0);
rand_temp(0) := temp;
END IF;
random_num <= rand_temp;
END PROCESS;
END;
After that i tried to add the random signal to a known signal to get a new signal so i can find PSD. I wrote a code for that and i am getting some errors. The code is
PACKAGE n_bit_int IS-- User-defined type
SUBTYPE BITS32 IS INTEGER RANGE -2**32 TO 2**32-1; -- -256 ~255
SUBTYPE BITS33 IS INTEGER RANGE -2**33 TO 2**33-1; -- -512 ~511
END PACKAGE n_bit_int;
LIBRARY WORK;
USE WORK.n_bit_int.ALL;
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.MATH_REAL.ALL;
ENTITY cumulants IS
x0 : IN BITS32;
x1 : IN BITS32;
x2 : IN BITS32;
x3 : IN BITS32;
y0 : OUT BITS33;
y1 : OUT BITS33;
y2 : OUT BITS33;
y3 : OUT BITS33
END ENTITY cumulants;
ARCHITECTURE Behavioral of cumulants is
COMPONENT random
END COMPONENT random;
BEGIN
PROCESS
VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0);
BEGIN
u1 : PORT MAP ( clk => clk1, random => rand_temp );
y0 <= x0 + rand_temp;
y1 <= x1 + rand_temp;
y2 <= x2 + rand_temp;
y3 <= x3 + rand_temp;
END PROCESS;
END;
The errors are
Error (10500): VHDL syntax error at cumulants.vhd(49) near text "PORT"; expecting "(", or an identifier ("port" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at cumulants.vhd(49) near text ";"; expecting ":=", or "<="
Please help me. Where am i going wrong.
    It could be because your design isn't meeting timing requirements. What does Timequest say about your design?
    How do you check the values in and out of your division? If you are using SignalTap, could you post a screenshot with the values you get and those you expected?
    I'd also recommend a larger CRC process for a more complex "Noise".
