14 years agoGenerating a signal (a VHDL description) with a well-defined frequency in a FPGA
Hello, In fact, I'm working on a project that aims to put a communication platform to interact with hydrogen sensor wirelessly. The platform consists of an evaluation board from Xilinx ML505 (o...
14 years ago --- Quote Start --- The platform consists of an evaluation board from Xilinx ML505 (on which there is a Virtex 5) --- Quote End --- This is an Altera group. You'll need to go and find a Xilinx group for device related help. --- Quote Start --- which will implement the baseband digital processing and another board (Software Defined Radio) for the analog front end that includes the blocks needed (modulator / demodulator, filter, LNA, PA, local oscillator) to communicate on the UHF band (900 MHz). The platform requires a 12-bit DAC and an ADC 12-bit to adapt the two boards. So I need help to generate a baseband signal (VHDL description) with a defined frequency, otherwise, I have trouble to describe the signal generator in VHDL --- Quote End --- The following has references that will help: http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100paper_hawkins.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100slides_hawkins.pdf Also look at the Xilinx DSP book http://www.xilinx.com/publications/archives/books/dsp.pdf Cheers, Dave
