14 years ago
Generate patterns through CPLD(MAXII)?
I'm new to FPGA/CPLD. Could any one help me?
I'm wondering if I can use CPLD/FPGA to generate some patterns to output pins? This is for some simple test purpose.
For example, under 50MHz clock, to generate pattern as "0011110000111100101010...."
As I know, the CPLD/FPGAs are to be programmed as logic functions.
Appreciate for the answers.
    I read through the articles and found that it's too difficult to me.
    Any starting materials that I can refer to generate serial patterns?
    Thanks!
    --- Quote Start ---
    --- Quote End ---
    Download the Byteblaster.zip file I posted here. There is an SPI shift register in there. It has a Modelsim simulation. Run it. Read it. Try to understand it.
    http://www.alteraforum.com/forum/showthread.php?t=32434&page=3
    Cheers,
    Dave
    Dave,
    I learned with the lpmshiftreg mega function but still got problems.
    I attached the simulation waveform.
    Basically, the serial output have no response after CLK enabled when d[7..0] was put as data input.
    Do you know why?
    Thanks!
    Cliff
    Hi Cliff,
    --- Quote Start ---
    Do you know why?
    --- Quote End ---
    Can you please upload a testbench for the device. That'll make it clearer whether you are using it correctly. If you need an example testbench to get you started, use the one on this thread:
    http://www.alteraforum.com/forum/showthread.php?t=32386
    Cheers,
    Dave
    Hi Dave,
    I tried lpmshiftreg in Megafunction of QuarterII and it works finally. Thanks for your patience replying me so many questions.
    Cliff
    Hi Cliff,
    --- Quote Start ---
    --- Quote End ---
    Great! But take the time to look at the Modelsim simulation example too. Its a very powerful tool, and worth learning.
    --- Quote Start ---
    --- Quote End ---
    You're welcome.
    Cheers,
    Dave
