14 years agoGenerate patterns through CPLD(MAXII)?
I'm new to FPGA/CPLD. Could any one help me? I'm wondering if I can use CPLD/FPGA to generate some patterns to output pins? This is for some simple test purpose. For example, under 50MHz clo...
14 years agoHi Cliff,
--- Quote Start --- I learned with the lpmshiftreg mega function but still got problems. I attached the simulation waveform. Basically, the serial output have no response after CLK enabled when d[7..0] was put as data input. Do you know why? --- Quote End --- Can you please upload a testbench for the device. That'll make it clearer whether you are using it correctly. If you need an example testbench to get you started, use the one on this thread: http://www.alteraforum.com/forum/showthread.php?t=32386 Cheers, Dave
