ScottShin's avatar
ScottShin
6 years ago
generate .jic file from .sof and .elf
I'm trying to generate .jic file from .sof and .elf that use Terasic's self-balancing car demo_nios_code practice. All .sof and .elf are not modified, but my .jic can't work like demo_batch_jic's .jic file. The programmer was also successful in my practice.
(tool: Quartus lite18.1 host PC: WIN10 Board: DE10-Nano)
I follow step like below:
1.turn .sof and .elf to .flash by instruction:
sof2flash --input=DE10_Nano_Bal.sof --output=hwimage.flash --epcs --verbose
elf2flash --input=DE10_Nano_bal.elf --output=swimage.flash --epcs --after=hwimage.flash --verbose
2.turn both .flash to .hex by instruction:
nios2-elf-objcopy -I srec -O ihex hwimage.flash hwimage.hex
nios2-elf-objcopy -I srec -O ihex swimage.flash swimage.hex
3.open "convert programming file" GUI configure like the attached picture:
Hope anyone can give me some advice, I will appreciate it.
(I also attach my program file. it wasn't modified.)
  • Hi,
    From the jic generation, I observed that you do not set the address for the hex file. I would recommend to set the address that you used based on your Quartus design.
  • JohnT_Altera's avatar
    JohnT_Altera
    Glad that you are able to resolved the issue. Feel free to file new forum if you have any other queries.
    JohnT_Altera
    • ScottShin's avatar
      ScottShin
      Thanks, I solve the problem. although at first, it jumps out massage "exceed flash memory", but I change SOF's property to compression.
      ScottShin
      Hi sorry took it took long to reply to you.
      I trying the way by the document. Added legacy_epcs_flash_controller in the Qsys, I also set Nios's reset_vector in epcs_flash_controller. then I convert the program file to .jic.
      I program successfully, but my function didn't work. seem like Nios doesn't boot right.
      That is my memory file.
      Meanwhile, I also try the Nios2 flash programmer, but GUI has a problem that can't read the Epcs layout patch file. So I type instruction to implement the flash programmer in Nios2 commend shell , then I got information after both flash programmer instruction finish.
      flash programmer instruction :
      #sof transfer to flash
      sof2flash --input="output_files/balcar_nios.sof" --output="software/balcar_soft_bsp/flash/balcar_nios_epcs_flash_controller_0.flash" --epcs
      #program sof flash
      nios2-flash-programmer "software/balcar_soft_bsp/flash/balcar_nios_epcs_flash_controller_0.flash" --base=0x1101000 --epcs --sidp=0x11020B0 --id=0x0 --timestamp=1603266025 --device=2 --instance=0 '--cable=DE-SoC on localhost [USB-1]' --program --erase-all --override=c:/nios2-flash-override.txt
      #elf transfer to flash
      elf2flash --input="software/balcar_soft/balcar_soft.elf" --output="software/balcar_soft_bsp/flash/balcar_soft_epcs_flash_controller_0.flash" --epcs --after="software/balcar_soft_bsp/flash/balcar_nios_epcs_flash_controller_0.flash"
      #program elf.flash
      nios2-flash-programmer "software/balcar_soft_bsp/flash/balcar_soft_epcs_flash_controller_0.flash" --base=0x1101000 --epcs --sidp=0x11020B0 --id=0x0 --timestamp=1603266025 --device=2 --instance=0 '--cable=DE-SoC on localhost [USB-1]' --program --override=c:/nios2-flash-override.txt
      result information:
      program sof.flash result 
      program elf.flash result 
      Any advice, I will appreciate.
