ScottShin
6 years agogenerate .jic file from .sof and .elf
I'm trying to generate .jic file from .sof and .elf that use Terasic's self-balancing car demo_nios_code practice. All .sof and .elf are not modified, but my .jic can't work like demo_batch_jic's .j...
- 5 years ago
From the jic generation, I observed that you do not set the address for the hex file. I would recommend to set the address that you used based on your Quartus design.
JohnT_Altera
5 years agoHi,
- ScottShin5 years ago
Thanks, I solve the problem. although at first, it jumps out massage "exceed flash memory", but I change SOF's property to compression.
