14 years agoGenerate a pulse?
Anyone can help me?
I need to generate a pulse for data load control in VHDL, which function I can use to generate a pulse? Thanks! Cliff2 Replies
Hi Cliffchen,
here is a classic pulse generator for one clock period in vhdl: edge_detect: process ( reset_n, clk ) begin if (reset_n = '0') then ff0 <= '0'; ff1 <= '0'; elsif (clk'event and clk = '1') then ff0 <= in; ff1 <= ff0; end if; end process edge_detect; pulse = '1' when (ff0 = '1' and ff1 = '0') else '0'; Now, if the "in" signal changes from '0' to '1' the output "pulse" is '1' for one clock cycle. - Altera_Forum
you will need a counter, and then generate the pulse when the counter is within a specified range.
