15 years agoGain control using fpga
Hi, i have four FIR filters and i want to control the gain in the output of each filter and then sum their outputs. The result is sended to an DAC. it is possible to control the gain in fpga...
15 years ago --- Quote Start --- i'm using the DAC to generate a white noise (14 bits LFSR - generated in fpga, maybe i should decrease the number of bits. But what happens, is the noise still be white?). --- Quote End --- Are you using the LFSR to create uniform noise or Gaussian noise? The difference relates to the power in the power spectrum. For a detailed analysis of LFSRs and examples of power spectra, see; http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/lfsr_tutorial.pdf) --- Quote Start --- I realy dont know. How do i calculate the SNR of DAC? --- Quote End --- The quantization noise floor will be at approximately 6*B. However, all DACs have a sinc-like output response (see examples in the above doc), so you have to inverse-filter your output signal, hence you lose SNR relative to the ideal. --- Quote Start --- My gain should go from -19 dB to 0 dB in steps of 1 dB. I need a multiplier or a divider (what is better, start with a -19 dbm and multiply to increse the gain or start with 0 dbm and divide to achive -19 dbm?) . Does the quantization noise apply? --- Quote End --- The quantization noise floor does not move. If you are planning on having just a noise output, then you can probably just treat the quantization noise as part of your signal. However, if you are trying to generate band-pass filtered noise, then the quantization noise sets your noise floor. Read these; http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100paper_hawkins.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/esc-100paper_hawkins.pdf) http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100paper_hawkins.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/esc-100paper_hawkins.pdf) --- Quote Start --- Each one of the filters output must be 0 dbm (maximum) at the DAC output. --- Quote End --- That comment does not really makes any sense. There is only one output and hence the output 0dBm. If N signals are each contributing a fixed power level, then each signal has to have 1/N power, or an RMS that is 1/sqrt(N) smaller. --- Quote Start --- Do you know how to calculate spurious emission? --- Quote End --- Of what? Do you have an antenna or board design you are trying to measure? You put it in an EMI chamber and measure it. Cheers, Dave
