12 years agoFull rate PHY selection
I need to generate a DDR3 PHY in Full rate mode for a Cyclone V part. I am using Quartus 13. I select "memory clock frequency:" different numbers like 400, 125, 200MHz. I see only half rate mode can be selected on "Rate on Avalon-MM interface". I need to select Full rate mode. Please advise.
First enable HARD_EMIF: (Hard Memory IF Controller) Then you can select full mode (related to the datawith - x4, x8 etc). See Altera SoC Handbook for details. regards, V.ZS. - Altera_Forum
Thanks for the reply!
It helped me to generate full rate PHY. One more thing: this option is only available if user wants to genearte both controller and PHY. I want to select the option "generate PHY only". I just generated both of them and going to remove the controller only. It is an option but I don't get why the GUI is like this! - Altera_Forum
you can only select Full Rate when using the Hard External Memory Interface (which includes PHY and controller). the fabric would not be able to close timing for a full rate controller, so they do not give you the option
