15 years agoFSM problem
Heyy I'm trying to make a video game in vhdl on de0 board and I need help about the following FSM. No error or warning. Does anyone notice a mistake??
thankss.type XY_REG_TYPE is array (0 to 19,0 to 9) of std_logic;
type AB_REG_TYPE is array (0 to 3,0 to 3) of std_logic;
type XY_NEXT_TYPE is array (0 to 19,0 to 9) of std_logic;
type AB_NEXT_TYPE is array (0 to 3,0 to 3) of std_logic;
type STATE_TYPE is (count,zero,left,down,right);
signal m : integer range 0 to 9;
signal n : integer range 0 to 19;
signal c,d : integer range 0 to 3;
signal ab_reg : AB_REG_TYPE;
signal xy_reg : XY_REG_TYPE;
signal ab_next : AB_NEXT_TYPE;
signal xy_next : XY_NEXT_TYPE;
signal state_reg, state_next : STATE_TYPE;
signal T_reg, T_next : integer range 0 to 10;
begin
FSM1: process (clk, reset, n, m, c ,d)
begin
if reset = '1' then
xy_reg(n,m) <= '0';
T_reg <= 0;
state_reg <= zero;
elsif clk'event and clk = '1' then
xy_reg(n,m) <= xy_next(n,m);
T_reg <= T_next;
state_reg <= state_next;
end if;
end process FSM1;
FSM2: process (SW(1), BUTTON, xy_reg, ab_reg, state_reg, T_reg, T_next, m, n, c ,d)
begin
xy_next(n,m) <= xy_reg(n,m);
T_next <= T_reg;
state_next <= state_reg;
case state_reg is
when count =>
if EndOfField = '1' then
T_next <= T_reg + 1;
if T_reg = 10 and SW(1) = '1' then
state_next <= zero;
else
state_next <= count;
end if;
end if;
when zero =>
if BUTTON = "111" then
if xy_reg(n+1,m) = '0' then
xy_next(n,m) <= xy_reg(n+1,m);
T_next <= 0;
else
T_next <= 0;
end if;
elsif BUTTON = "101" then
state_next <= down;
elsif BUTTON = "110" then
state_next <= right;
elsif BUTTON = "011" then
state_next <= left;
end if;
when down =>
T_next <= 0;
else
T_next <= 0;
end if;
when right =>
if xy_reg(n,m+1) = '0' then
xy_next(n,m) <= xy_reg(n,m+1);
T_next <= 0;
else
T_next <= 0;
end if;
when left =>
if m >= 1 then
if xy_reg(n,m-1) = '0' then
xy_next(n,m) <= xy_reg(n,m-1);
T_next <= 0;
else
T_next <= 0;
end if;
else
T_next <= 0;
end if;
end case;
end process FSM2;12 Replies
I don't understand what you are saying gabrigob. What is he supposed to use instead of integers? As long as you specify ranges for each one of them the synthesizer will be smart enough to just generate the required width for the signals.
It is hard to tell if there is a mistake if you do not know what this piece of code is supposed to do.
Anyway, I would suggest you something about VHDL coding style. Please, take this advice as something that comes from a guy that studied VHDL some long time ago and now uses it for its job. I mean that I may be outdated at academic coding style... Why you make use of integers as signals for synthesis? It seems that a large bus of bits travels around your design and it is used as decoder for a multiplexer. The multiplexer is implicit in the array indexing. Someone taught to me that this can lead to sub-optimal synthesis results. This teaching, as I told, may be outdated or too much conservative (for "company" compatibility with older tools that produced sub-optimal synthesis results).
