16 years ago
From FPGA to Monitor
Im wondering if it possible to store some pictures file in the FPGA and having them loaded to the monitor screen?
If yes, how do I do that?
thank you very much! =)
    --- Quote Start ---
    Same answer from me, try to look into some example code provided with the board and read the manual from Altera. If you still want to try to fit your Image into the onchip_memory, then I advise to start from SOPC. When you open any module added to a Nios-CPU, there for most modules is a link to the description available. (button in the right upper corner of the opened module) So you could read into that specific description.
    Good luck.
    --- Quote End ---
    thank u very much!
