13 years agoFrequency of operation of M9K bram
Hi, Does anybody know where/how to find the operating frequency of a block ram? I particularly need M9K and M10K. I was not able to find them in the altera documentation. Kindly let me know if ...
13 years agoHi Dave,
Thanks for your quick response :) Appreciate it. I have attached the file : test_harness.v . I am working on multiported memories. Since I was suggested to connect input and output registers to the RAM {since RAM pins cannot be connected directly to IO pins} I have 1) To reduce the number of IO pins used, have instantiated and connected word-wide shift-registers to only "data inputs" of the RAM. [ Address inputs are left unconnected since the address comes from the control unit and not from IO pins] 2) Then comes the RAM instance itself. - This is the one which is not being inferred. This module if I synthesise it separately, is inferred as M9K blocks. But now it is implemented in Logic cells. 3) Instances of word-wide registers are connected to the RAM output. Kindly let me know what I could do so that the RAM infers altsyncram component.
