17 years ago
Frequency divider with clk en.
I want to make a frequency divider (50 Mhz to any value, 560khz ), I am working with a counter like a freq. divider but there is a warning in Quartus II:
Warning: Found 1 node(s) in clock paths which may be acting as ripple and/or gated clocks -- node(s) analyzed as buffer(s) resulting in clock skew
I read that using a CLK EN is the best way to make a freq. divider, but a I don't know nothing about it, DO YOU HAVE INFORMATION OR EXAMPLES ABOUT? HELP ME PLEASE
    Ok, if I compile only this code there is no problem, the problem is when I connect this freq divider with the cordic block (I am working with schematic diagram). Each block, cordic and freq divider, works fine individually.
    Are you trying to clock the cordic block using the clk_en_568k signal by any chance? What you need to do is clock the cordic block from your 50MHz clock, and supply clk_en_568k to the cordic block as a clock enable signal. If the cordic block doesn't have a clock enable you'll have to modify it to add one.
    Thanks !!!!!!!!!
    It was the solution sharkybba, cordic with clock enable ......
    Thanks to all for your help.....
