Frame buffer IP
We use 2 frame buffer IPs in our design.
1- The first frame buffer: takes its data (din) from DVI Input IP (VGA_IN_INST) and writes this data into an SDRAM through the SDRAM controller. We do not use the read & dout of this Frame buffer . So, these unused interfaces are connected to an empty dummy component (reference to the service request no. 10773449 ) 2- The second frame buffer: should read the data written by the first Frame buffer in the used SDRAM and gives this data to the DVI out IP (VGA_out_INST). W e do not use the write & din of this Frame buffer. So; these unused interfaces are connected to the same dummy component. Taking into consideration that, the dummy component interfaces are Avalon. Kindly advise about the following 1- Is it applicable to use a Frame buffer to write data in SDRAM and another Frame buffer to read this data from the same SDRAM as described above? 2- How to make sure that the second frame buffer reads the data from the same addresses used by the first frame buffer for writing in the SDRAM? This question is because the addresses are nit indicated when we instantiated the frame buffer in SOPC builder28 Replies
--- Quote Start --- We use 2 frame buffer IPs in our design. 1- The first frame buffer: takes its data (din) from DVI Input IP (VGA_IN_INST) and writes this data into an SDRAM through the SDRAM controller. We do not use the read & dout of this Frame buffer . So, these unused interfaces are connected to an empty dummy component (reference to the service request no. 10773449 ) 2- The second frame buffer: should read the data written by the first Frame buffer in the used SDRAM and gives this data to the DVI out IP (VGA_out_INST). W e do not use the write & din of this Frame buffer. So; these unused interfaces are connected to the same dummy component. Taking into consideration that, the dummy component interfaces are Avalon. Kindly advise about the following 1- Is it applicable to use a Frame buffer to write data in SDRAM and another Frame buffer to read this data from the same SDRAM as described above? 2- How to make sure that the second frame buffer reads the data from the same addresses used by the first frame buffer for writing in the SDRAM? This question is because the addresses are nit indicated when we instantiated the frame buffer in SOPC builder --- Quote End --- hi: are you still focus on studing the transmitting video signals though ethernet to pc? I have just realizing sdram data transmitted to TSE_MAC by SGDMA to PC, now,I want to save the video data to SDRAM ,now I refer the demo :VIP and want to make it as a start project ,but I find the software is complex... so ,I hope to communicate with you.my email is [email protected]. thanks - Altera_Forum
I use the frame reader in my design with the following settings:
Bits per pixel per color plane: 8 Number of color planes in parallel: 3 Number of color planes in sequence: 1 Maximum Image width: 1920 Maximum Image height: 1080 Master port width: 64 Read master FIFO depth: 1024 Read master FIFO burst target: 64 Use separate clock for the Avalon MM master interface: unchecked Kindly confirm if the following calculations for number the words and the Single Cycle Color Patterns are true or not 1- // Words IOWR(FRAMEREADER_BASE, 5, 259200); // (1920*1080*8*3)/48= 1036800 2- // Single Cycle Color Patterns IOWR(FRAMEREADER_BASE, 6, 2073600); // 1920*1080=2073600 number of pixels in the frame multiplied by the number of single cycles required to represent one pixel - Altera_Forum
Thank you for your co-operation. I use the frame reader in my design with the following settings:
Bits per pixel per color plane: 8 Number of color planes in parallel: 3 Number of color planes in sequence: 1 Maximum Image width: 1920 Maximum Image height: 1080 Master port width: 64 Read master FIFO depth: 1024 Read master FIFO burst target: 64 Use separate clock for the Avalon MM master interface: unchecked Kindly confirm if the following calculations for number the words and the Single Cycle Color Patterns are true or not 1- // Words IOWR(FRAMEREADER_BASE, 5, 259200); // (1920*1080*8)/64 = 259200 2- // Single Cycle Color Patterns IOWR(FRAMEREADER_BASE, 6, 2073600); // 1920*1080=2073600 number of pixels in the frame multiplied by the number of single cycles required to represent one pixel - Altera_Forum
Is there any component don not need nios to be used for reading data from the SDRAM (instead of the Frame Reader)?
Thank you for your reply.
If i use the "Clocked video input" instead of the "Clocked video output", how can we connect the dout of the "clocked video input" to 2 din of two "frame buffers" - Altera_Forum
I have a similar situation in which I just want to use a simple SOPC Builder design to frame sync 4:2:2 YCbCr (720p) video in the un-referenced 74.25MHz clk domain... to black burst sync'd 74.25MHz clock domain by using the Clocked Video Input -> Frame Buffer (with DDR2 intf.) -> Clocked Video Output
But even though I uncheck the "video in and out use the same clock" option on the CVI and CVO general parameters options I still get an error message from SOPC builder (Quartus II v10.0) if I try to use a different dout-to-din (or din-to-dout) on the interface between the Frame Buffer and the Clocked Video blocks. So then what is the purpose of the "video in and out use the same clock" parameter? What is the simplest way to solve my problem of differing frame rate read and/or write using the Video and Image Processing Suite blocks? - Altera_Forum
yes, just use the splitter core as told by josyb. It's easier than my solution, I didn't know that this core existed ;)
In SOPC Builder, i want to connect the dout of the "clocked video input" to 2 din of two "frame buffers"
Kindly confirm if it is applicable or not - Altera_Forum
Thank you for your replies.
Is it applicable (two replies) when i want to connect the dout of the "clocked video output" to 2 din of two "frame buffers" using SOPC Builder - Altera_Forum
You can use an Avalon-ST Splitter Core to achieve that.
