8 years agofpga startup problem
Good afternoon, members of the forum.
I have stratix V. I have such a problem. I write down the firmware in the epcq through the AS. The process is normal. In the firmware, I activate one of the LEDs on the board Starting the card, nothing happens. Then he began to notice that the LED all the same blinks once during the start. In this case, if I change the firmware to another LED, the other LED will blink at the start. That is, the FPGA begins to be configured. And then nothing happens. I checked the status pins with the voltmeter. CONF_DONE = 0.1V (is low signal?) nStatus smoothly changes 0.7V - 1.3V = low signal. According to the documentation, this is similar to "Configuration Error Handling". True today, I inserted a card in the pci-e, and my LEDs stopped blinking at the start, according to my firmware. CONF_DONE = 0.1V (is low signal?) nStatus = 0V nCe = 0V nConfig = 3V Сontrol outputs on the board (just in case): 3.3V = 3.4V 3V = 3V 2.5V = 2.5V VTT = 0.38V VCCINT = 0.9V VCCIO = 2.59V Would I be happy with any advice, what kind of problem is this? Where to start searching. Thank you in advance ps. Altera Stratix V 5sgxma7k2f40c2n board Gidel ProceV13 Replies
Many thanks to the support for patience and my non-professional questions. I replaced the power supply chip, restored Vccpt = 1.5V and the chip came to life.
--- Quote Start --- Hi, It is a power issues If the POR monitored power supplied (from Table 11-2: Power Supplies Monitored and Not Monitored by the Stratix V POR Circuitry) does not reached and stay the appropriate voltage level, the nSTATUS will be low. You can check each power supply voltage level requirement from the datasheet. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- Thanks again, there is no VCCPT 1.5 volt supply. I will look for the cause - Altera_Forum
--- Quote Start --- Hi, It is a power issues If the POR monitored power supplied (from Table 11-2: Power Supplies Monitored and Not Monitored by the Stratix V POR Circuitry) does not reached and stay the appropriate voltage level, the nSTATUS will be low. You can check each power supply voltage level requirement from the datasheet. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- thanks, I will check - Altera_Forum
It is a power issues If the POR monitored power supplied (from Table 11-2: Power Supplies Monitored and Not Monitored by the Stratix V POR Circuitry) does not reached and stay the appropriate voltage level, the nSTATUS will be low. You can check each power supply voltage level requirement from the datasheet. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
--- Quote Start --- Hello, thanks Jtag does not start. I can not program sof In verilog, i program the user LEDs so that they are always on. When the power is turned on, these LEDs blink 1 time and nStatus smoothly changes its value from 0.7v to 1.3v and back. Could you tell me at which points (pins), you can check the power? I have control points 0.9, 2.5, 3, 3.3 on the board, they all show the correct values --- Quote End --- If you say the Jtag does not start, then in your earlier message , are you referring to the compilation process?. --- Quote Start --- I also worry that when I program in quartus my epcq256 , the first 26% of the process takes a long time (about 3-4 minutes), and then the process goes to 100% very quickly (in 1 second). At the same time he writes that everything went well. On another my chip (cyclone IV) the process is smoothly slow all 100%. Maybe this is where the problem lies. --- Quote End --- A few things: 1. Have you assigned a valid pin to signal_1 ? (which is connected to the User LED - usually given in the user manual along with the development board. This assignment will be made in the QSF file or in a TCL file which you can source). If you do not manually assign a valid pin, it will not work. 2. Ensure the JTAG connection detects your board, and program it using the correct FPGA sof file. If you can give us more details about the process you are following, we can help. - Altera_Forum
--- Quote Start --- Hi, 1.Have you programmed sof file successful? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- Hello, thanks Jtag does not start. I can not program sof --- Quote Start --- Hi, 2.Is nStatus low form power on state? When the nSTATUS is low, the possibility is either due bit-stream corruption or power issue. --- Quote End --- In verilog, i program the user LEDs so that they are always on. When the power is turned on, these LEDs blink 1 time and nStatus smoothly changes its value from 0.7v to 1.3v and back. Could you tell me at which points (pins), you can check the power? I have control points 0.9, 2.5, 3, 3.3 on the board, they all show the correct values - Altera_Forum
1.Have you programmed sof file successful? 2.Is nStatus low form power on state? When the nSTATUS is low, the possibility is either due bit-stream corruption or power issue. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
--- Quote Start --- HI, Okay, problem solved? --- Quote End --- I do not know yet. The chip never starts. conf_done = 0.7v = pulled low nStatus = 0.7..1.3v =pulled low and then high These signals, according to the documentation, mean configuration error (from epcq256 by active serial). At the same time, the programmed user LEDs light up and go out at once (they should glow constantly). This means that the FPGA is still being configured. I read that this is the error of the crc sum, but I have not yet figured out how to solve it. I also worry that when I program in quartus my epcq256 , the first 26% of the process takes a long time (about 3-4 minutes), and then the process goes to 100% very quickly (in 1 second). At the same time he writes that everything went well. On another my chip (cyclone IV) the process is smoothly slow all 100%. Maybe this is where the problem lies. - Altera_Forum
--- Quote Start --- I found that the conf_done pin is connected through a 10k resistor not to Vccpgm (3V), but connected through a 10k resistor to a neighboring i/o pin --- Quote End --- HI, Okay, problem solved? - Altera_Forum
