8 years agofpga startup problem
Good afternoon, members of the forum. I have stratix V. I have such a problem. I write down the firmware in the epcq through the AS. The process is normal. In the firmware, I activate one ...
8 years ago --- Quote Start --- Hi, 1.Have you programmed sof file successful? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- Hello, thanks Jtag does not start. I can not program sof --- Quote Start --- Hi, 2.Is nStatus low form power on state? When the nSTATUS is low, the possibility is either due bit-stream corruption or power issue. --- Quote End --- In verilog, i program the user LEDs so that they are always on. When the power is turned on, these LEDs blink 1 time and nStatus smoothly changes its value from 0.7v to 1.3v and back. Could you tell me at which points (pins), you can check the power? I have control points 0.9, 2.5, 3, 3.3 on the board, they all show the correct values
